How much Oil?
TD_Maker
I am finally finished rigging my new-to-me 2003 90 HP Johnson. I have decided to use the Oil Injection system this Bombardier was designed to use. I have taken some advice and pre-mixed a (50-1) 6 Gallon tank and running this tank along with the Oil Injection to confirm the system is indeed working. Here is the question (stupid or not)
How much oil should be used (out of the oil tank) if I burn the entire premix 6 Gallon tank? I have marked the tank for a starting point.
Thanks for the help.
Re: How much Oil?
going by what i have read the injection pump will run 100:1 at idle and 50:1 at wot so im not sure the oz's will be accurate. 6 gallons at 50:1 will be 15.6oz's @ 100:1 it will be 7.8oz's so it should use at least 7.8 to 15.6oz's.
