I’m totally confused after doing a test run of my rebuild it’s 16’ x 6.5’ semi-v hull weight is estimated at about 1500lbs with twin 30hp Hondas. The engines have stock 9.25”x12” props fitted. I’m unable to reach anything near the 5,000 to 6,000 rpm WOT range listed by Honda. Here are some random rpm and speed values that I was able to get, 1900rpm/21mph, 2200rpm/21mph and 3800rpm/26mph (mph was taken on GPS). 3800 was the highest rpm I was able to obtain at about ¾ throttle because of other issues (porpoising, which I need to resolve).
In order for me to achieve the proper rpm range how many inches of pitch do I need to go down? Honda has props from 8” to 11” in pitch. Which would be the best choice for me to start with? Any input would be greatly appreciated.
