Model 1990 48SPL E48ESLESA
I have my lower unit driveshaft removed and the area where the needle bearing sits just above the thrust bearing near the top of the shaft. My main question is how much is to much? I have used a little bit of strip sandpaper used for cleaning up roughness, 120 grit I believe. I can lightly see the outline of where each needle bearing sat against the shaft. WHen I bought the unit it had the plastic nut on the shift rod backed out I had found after a water test which had been performed due to initially the unit draining water when I purchased it.
I don't really want to spoend $465 on a new driveshaft unless it's really necessary. If I were to try to run it how soon would I realize that it would work or not? I am also having to replace the forward gear. From looking at the forward gear and reverse gearthey look the same with the exception of the sleeve. Can the sleeve be removed on a new reverse gear and it installed in the forward position? I am also getting a new dog gear. I have the seal kit, water pump. I plan on replacing the thrust washers, all bearings and races being it was in the water.
With the Torrington bearings the lower unit uses can I just take those numbers to Malloy Bearing and replace with equal or cross referenced or are the bearings of a "certain grade" where they have to be of marine grade or is there such a type
If I knew how to add photos of the shaft I would to help speed the process. I'd like to get this boat on the water sometime this weekend if possible if I can find the parts I need.
Any help appreciated. Thanks !!
