Re: how much set back is too much on a 20' runabout
Nobody makes stupid mistakes on purpose.
This I understand as many bad things are not meant to happen. But IF the key is not in the ignition while anchored or afloat and is sitting on the dash, then the only way for the motor to start would be divine intervention or one of the most fantastic series of electrical shortouts I could imagine.
Anyways back to topic. I think I'm going to have to go with either the 10" or 12" bc of clearance issues with molded swim platforms and my new motor being able to fully swing/turn. I think the 10" will work (clear the motor of hitting the swim platforms). I just would consider the 12" if it will not be deterimental. I am going to run stainless steel smart tabs as recommended by nauticus which should alieveate most of the issues of such a long bracket. The transom is rock solid. A nice sandwhich of three brand new 3/4" pieces of marine ply, new stringers of 3/4" clear pine and knee braces of the 3/4" clear pine w pieces of 3/4" marine ply wrapped on either side of the clear pine that will push on the transom. So strength in that way is not a concern.
I'm confident I can run the 10" setback, but would the 12" be too much?
And by the way thanks to people for commenting and adding info. It is appreciated
