Last weekend tried out the new 25 HP Yamaha 2 stroke. Still breaking it in but man did it haul butt when I gunned it. Boat is an older Hypalon Zodiac Mark II Grand Raid. This is the 2nd time I have used the boat.
Question I have is about spray and water in the boat. I got quite a bit of water in the bottom of the boat by the end of the day. running flat it was below the floor boards but when I gunned it it would pool at the back and then flow forward and spout out the keel hole when I let off the throttle. (daughter said it looked like a whales blowhole) Figure 2+ gallons were in boat by the end of the day.
I took a hose and filled the boat up with water to test for leaks-none. It has to be from spray over the transom. What puzzles me is I really didn't see more than a few drops at a time coming over the stern but I guess it can add up. Anyone have something similar?
My boat has 2- 45 degree splash guards on it. and the valves in the plugs make me think a lot of folks have to use the drains- so I am wondering if this is just typical for an inflatable and the nature of the beasts.
Someone suggested running with the plugs out but I don't know if that is very wise. I guess there are flapper valves in the plugs but that makes me nervous as does leaning over the stern to pull plugs in the middle of the water if I get big swells or worse trying to put them back in if the flap valve has issues.
So, just curious how much water if any do you get in the boat when running?
Is this something I need to work on or look for or do I need to just relax as everything is normal?
