How much $$ to replace stringers and deck?
109jb
I'm sure it's been covered many times, but I just can't seem to find a post that puts dollars to floor and stringer replacement for a boat about the size of mine. I have a 1988 Sea Ray Seville, 16 foot bowrider that is in my avatar that I'll be gutting to replace deck, bow seat platforms, and probably stringers. For wood, I'll be going with AC exterior grade plywood, or treated plywood if I put it off till spring. I'm trying to figure out how much mat and resin I need to buy. I already have a bunch of 8 oz cloth so won't need any woven. For you guys that have done this before, what kind of estimates do you have for materials and cost for a 16 bowrider? Also, where is a good place buy the resin and mat?
109jb
Re: How much $$ to replace stringers and deck?
Oh yeah, I forgot. How much foam do you think I'll need. It has foam under the deck except down the middle where the ski locker is and the fuel tank.
oops!
if you use polyester resin.......and you have a cloth product...you will still need csm..........so im guesstimating approx $6-700 bucks......that is for everything......including pt ply.....
but.....you forgrot to mention the transom.....:eek: :eek:
109jb
That's about what i was expecting. How much resin and CSM would you guess I would need and where is a good place to order online from? Thanks.
zach103
for foam i have a 17ft and i used the 2lbs foam from us composites. i used 3 set and had some left over for any mess up..
109jb
Thanks Zach. If I understand right, you used 3 of the small 4 lb kits of the 2 lb density foam. Right?
jcsercsa
HAy 109jb, I spent about 7 to 8 hundred on my 15.4 tri-hull , I used epoxy on mine , love that stuff !! on the foam i used the 2 lbs and could only stuff two set of the 6 lbs cans !! John
