How much to thin primer for hvlp
boatnut74
Getting ready to primer a project and can't find much information on how much to thin it. I'm using rustoleum clean metal white primer with a harbor freight hvlp. I also have majic reducer I can use. Just looking to find out at what percentage to thin it.
gm280
Zool, that data sheet is pretty interesting. The only thing they don't cover IS the HVLP spray gun tip size and air pressure. Usually a data sheet even covers the tip size for their primers and base paints. A 1.4mm to 1.5mm tip size is on the small size for primers. So it may take a little more thinning then 5%. But I would start there as well. Usually 1.8mm to 2.0mm is a good primer tip. But not absolutely necessary if you can work with the material to be sprayed. But thanks for linking the datasheet. I was interested in how it compares to PPG JP202 2k primers or even Epoxy primers. JMHO!
zool
Yea GM, I always try to post the tech sheets, if more ppl followed them, there would be less mishaps.
Im not a big fan of thinning primer too much, being that its the adhesion layer....any residual solvents lessen the effect, imo.....but ive sprayed this primer a few times...cant remember exactly the ratio, but its not real thick like a build primer....it flows more like an epoxy, so the lesser tips work fine
And few tech sheets can compare to PPG's P-sheets they give it all and more ;)
For boats, my choice would always be PPG acrylic U or Alexseal for Poly...
Woodonglass
Yup, I bought a 1.8mm gun off eBay just so I could shoot my Rustoleum primer without thinning it. Paid $35 bucks for it. Works Great!!!
boatnut74
Thanks. Thinned around 10% with mineral spirits and it sprayed very well.
