I just replaced a 13.75 x 15 aluminum prop on my 2001 Mercury 125 on my pontoon. I got a 13.25 x 13 four blade Solas Rubex prop. I used the new thrush washer and the new retaining washer and nut, but when I tightened it down the prop would not turn unless I backed the nut off a little. When it does turn there is just a very slight wobble to it. I did put on the rubber ring around the front of the prop hub but I have not had one of the same kind of rubber hub that this prop uses and there were no install info. Should this be torqued down to any certain specs, or just tightened against the rubber hub until it will just barley turn freely? I have not been able to get on the water but hope to in the next few days and don't want to mess up a new prop or motor. Thanks for all the help that I am sure will be forthcoming.
