How often 2 use seafoam??
WAVENBYE2
We are leaving fri. to go camping over the weekend, I have all the maintenance done on engine and sterndrive, Does every one use sea foam beganing every season? Is it ok to use full can for full tank(not sure gallons.)
Coors
Re: How often 2 use seafoam??
1 oz per gallon; pour the rest in your car/truck.
180shabah
I have used it as a fuel stabilizer, no problem treating the entire tank.
WAVENBYE2
Thanks guys, I haven't used any this season, I'm trying to see in the manuals how many gallons I have. I didn't want to hurt the engine by using to much. RPM's still a little low, I hope this might help. Thanks Pat
Bry21317
You might also try the Deep creep aerosol version, it really cleans it up. You spray it in the Carb or into a Vacuum line on the Intake, if you don't have a carb.
This is what I have always used in the past, it works better than the stuff in the tank to me. I do both, but a good shot of the Aerosol version really works, then put a can in the tank to clean the rest out.
Bryan
Coors
fill the tank, then figure the gallons, then dump it in.
It will be mixed by the time you hit the ramp.
WAVENBYE2
Will do !! Thanks, I get get back on forum Mon. to let you all know how it went. I do have a couple of more questions too about spark plugs, I have them at .35(seloc man.) another manual says .40 another says .45 could this affect rpm's too
moser42
Where is seafoam and deep creep sold?
I'm in ontario and no boat dealers in my area have it.
Would the Canadian Tire motomaster "combustion chamber cleaner" do the job? It's not in an aerosol can and it says on the bottle to pour down throat of carb but that could be very hard on some motors depending on location and setup of carb. so do I mix it with the gas? I have seen this combustion chamber cleaner made by a few different companies but havent found seafoam or deepcreep.
Thanks!
WAVENBYE2
You don't have an auto zone,advanced auto or NAPA automotive stores in canada ??? Any auto parts store should have it...Pat
WAVENBYE2
OK, Thanks every one I found the little tag on tank(30gals.) I used it in my wifes jeep and I can tell a big difference, just like new. Thanks again..Pat
plassiter1
Thanks!
its sold at NaPa in canada
you will find it
simon_canada
yup - I got my seafoam at NAPA here in Ottawa (ontario for those who didn't know!)
moser42
Thanks! how much $$ and what size bottles does it come in?
WAVENBYE2
It cost about close to $8.00 US. I believe 16 fl. ounces I am picking some up today along with radiator fl. I can let you know when I get back..Pat
88wellcraft
I followed the directions on the can.....poured about 1/3 of the bottle (very slowly) in the carb while it was running and the shut the engine down. Let it sit for about 5-10 minutes....fired it back up. Smoked like crazy for a few minutes and you shoulda seen the gunk come out the exhaust:D
WAVENBYE2
I'll try it !! Leaving in the morn. for the week end !!
