scott, What would be the best way to weigh it? I know I could take the trailer with boat on it to local waste management for a total weight, then put her in water, go back and weigh empty trailer. That'd be the best. But would it be OK to splash her with those cracks? I'm thinking yes, for the float test and weighing, but looking for thought on that before I do splash her at all...
@Wood & sphelps... So what's the best way to check transom, stringers and decking? When I was looking at her originally, I walked and put weight everywhere I could step on the deck. Intentionally went to the corners at transom and all along the sides... Nothing budged.. No flexing that I could tell. As for transom, I pulled up on the motor and the transom didn't seem to bow, flex, or move at all.. Also did the screwdriver tapping thing.. No dull thuds that I could find...
As for the stringers, the research I've done on this hull so far seems to indicate the stringers are wood wrapped in glass, and should be foam flotation I think it was. (Balsa was a flotation option for the year too, but the max HP is 80, and that max hp listed foam as floatation.)
What is the best way to know for sure if she really is hiding things on me?
I really appreciate the help. I got lots of help in the engine section, and learned enough that I actually was able to answer a couple questions for others!
(That felt good! lol)
Anyway.. I thank you guys, and look forward to your thoughts and suggestions...
