Re: How serious is pitting I see on my lower unit?
Get all the paint of in the surrounding area
give it a good coat of the proper etching primer and re-spray the area.
if it was me i would rub down as much of the gearbox as possible and completely re-prime and re-spray the whole gearbox.
If you leave this like it is it will get worse and will end up causing a lot of damage and possible failing when your out on the boat.
Any exposed alluminium will get attacked if not coated with something like paint etc.
Its not just salt water that attacks, its also fresh water as well, thats why their is different types of anode available for
both salt water and fresh water.
But looks like your NOT gonna have any problems at the moment as it dont look too bad, ive seen a lot lot worse
even to the point where oil was seeping through the bullet on the gearbox !!!!!!!!!
for that its a big re-pair involving ali welding etc, you dont want to let it get that bad or big bucks are needed.
2 hours of rubbing it down with wet n dry paper then spraying will make it like new again.
i wouldnt be too concerned but would definitely get some paint on it ASAP to stop it getting worse.
Make sure you get it very clean,even use a wire brush to make sure any dirt and grease is gone before the primer.
Do make sure its a primer for alliminuim and make sure its for marine use.
Plenty of nice light coats of the primer then the blue and then a couple of nice clear coats of laquer will have
it looking like brand new.
Below are pics of my little suzuki 30 half way through rubbing down and then final finnish.
My engine leg looked a lot worse than yours when i started it, but i reckon it looks pretty good again now.
hope this helps.
phill...
