I have a 04' Sea Ray 180 and had the bimini top installed by the dealer last season. The mounts where the legs of the bimini attach to the boat are screwed in, with whit small screws in my opinion. To me it seems like that's not much to hold those mounts to the fiberglass of the boat. Is it suggested anywhere that you drill completely through the fiberglass where those mountings are located, put a backing plate on and bolt them to the boat? It just seems when your running across the lake, that top likes to shimmy around alot and I know there has got to be tremendous pressure on those little screws. Or, should I just leave it alone and when the screws do work there way out, just bolt through with a backing plate then? Thanks for any help!
