Re: How small a kicker can I get away with?
As you know, boats that plane have many speeds, including, but not limited to: (1)displacement speed (the maximum speed a boat will travel through water: there's a mathematical formula that you can use for calculation); (2) minimum planing speed (when a hull "breaks through" displacement speed and begins to plane (obviously, some boats, because of hull size, design and/or horsepower limitations are never intended to plane); (3) maximum plane speed (a function of horsepower, torque, prop size/pitch, etc.) There's a practical limit to planing speed, but I don't believe there's a theoretical limit. There's also stop and go
<br /> I have a smaller motor because when I want to troll it's quieter and more economical. I mention the size because it happens to push my boat to its maximum, non-planing (i.e., displacement) speed.<br />The reason I have a bigger motor is that I've discovered it's hard to get my 24' boat to plane with a 9.9 hp. four-stroke Yamaha...
So I've discovered this 200 hp Johnson, which happened to be on the back of the boat when I bought it, works nicely for the purpose of getting somewhere faster. Does it control the boat better. Yeah. Surprised?
