How small is too Small of a diameter
Dhadley
Re: How small is too Small of a diameter
Those props are designed to be run on smaller gearcases. Not that it won't work but the correct size props will work much better. Generally speaking props in the 14 to 15" diameter range will work much better on a Bravo.
Ayuh,... That's an Outboard prop, the prop Barrel is also smaller, 'n it'll ventilate at the prop/ gear case junction....
krisnowicki
I ordered this prop and I am getting 4800-5000 rpms and the response is awesome I can plane out at 3000 and I am getting about 11% slip
steelespike
Thats great; mighty quick service and around a holiday weekend to boot!
