How thick aluminum for floors?
jitterbug127
I’m restoring my boat. It’s time to get rid of the wood and install aluminum floors. I’m trying to decide on how thick of flooring I should go with 1/16th, 1/8th or something else? I will be putting foam under the aluminum.
I have worked with aluminum sheet and plate for the past 30 years, the last 20 in a marine environment.
for a boat, you want 5000 series aluminum. 5052 is softer, however forms easy. 5083 is stronger, however doesnt form easy
1/16" aluminum will dent if you pick it up wrong
1/8" aluminum will dent with your thumb
3/16" will be OK if your structure grid will support it properly. we use no more than 12" centers on the support tubes.
1/4" will span about 24"
they all will eventually dent in the area where you stand unless you have a good structural foam underneath.
there is a reason that its not used.
if you are determined to do an aluminum floor. look at the aluminum decking from T&C or Eastern Metals. https://www.tc-alum.com/products/industrial/decks-docks-seawall/ works OK for van bodies, work platforms, docks, decks, etc.
