Serf27
- Joined
- Aug 23, 2018
- 167
Hi everyone, as I’m putting my clutch pack together, there is a rod that goes through the clutch pack shaft(the shaft that holds the clutches and discs) and puts pressure on the clutch pack from the starboard side and pushes the clutches against a washer and a c clip on the port side.
The clutch pack shaft has a bolt that passes through it and you tighten the bolt to put pressure on the rod that goes across the shaft.
How tight should that bolt be pushing against the rod to push the clutches together?
I’ve narrowed it down to a few settings, which should it be?
1.) Snug enough where the clutches don’t slip, but I can still tilt the drive with almost no force by hand.
2.) Tight enough to the point where It takes a great amount of force to tilt the drive by hand.
3) Tight enough where I can’t move the drive at all by hand.
4.) Tighten the bolt so it pushes the clutches as tight as possible.
Here are are some pictures.
One picture show the clutch pack assembly sitting in oil with the rod ground across the shaft.
One picture shows the Allen key head bolt which tightens the rod.
One picture Won’t upload but it just shows the bolt threading into the shaft and making contact on the rod. I’ll resize it and upload it if you guys need to see it.
thanks in advance.
thanks in advance.
