22E6441
- Joined
- May 29, 2008
- 376
Yes, yes...deck....
I've read through practically all the threads in this forum, and while I can say I know how to do stringers, transoms, and install new decks, I don't know how to best tackle my soft spot. Nothing really does a very basic "how to start cutting your deck" tutorial. All other threads end up doing a full resto it seems....I'm trying to be optimistic, but need best case scenario instructions.
I want to cut out my soft spot and try to patch it.
What is the best way to do this in the most non-destructive manner? I was thinking of drilling a hole and then using a jig saw to cut out the bad spot. I might need to cut all the way to the inside corner of the boat where the deck meets the gunwale, but I don't want to damage the outer hull. How do you cut a hole out and then be able to put in a patch? I don't know where my strings are. Should I instead cut an area out right across the boat? Right from gun to gun and about a foot and half long? Is that a better approach?
