How to add lower unit gear oil
Laddies
Banned
Re: How to add lower unit gear oil
The drain screw is on the same side front, bottom of the bullet. Fill from the bottom drain till it comes out the top vent screw in you photo
smokeyblaze
Ok I found it , but what I don't understand is how the lube stays in the lower unit with the all the holes in it.
les morgan
there is actually only three holes in the lower unit. The drain hole-the vent
(upper)hole and the big hole for the propeller shaft. The Bullet part of the
lower unit is a closed system...
Alden
If you haven't already, invest $10 in a gear lube pump. Lots easier than squeezing tubes.
saumon
Thoses holes were not part of the enclosed gears system. They are water pick-up holes for the water-cooling system.
Moody Blue
Negative Saumon, you missed what was highlighted in the photos.
Can't remember seeing them on my motor but they could be drain holes for water from the midsection. Not likely access to the actual LU gearcase.
saumon
Sorry, i can't open the pics at imageshack so i thought he talks about these holes. I didn't see anything on the thumbnails...
emckelvy
Not sure what gaskets you need, for the drain plug/screw?? You can find parts diagrams for your motor here:
http://www.mercruiserparts.com/SelectModelType3.asp?class_id=2
Then you can look up parts numbers at this site in the Parts section or try www.boatfix.com
As far as the holes you have circled in red in the pics, they are "cavity drains" which will allow water to drain out of the "free flood" areas of the lower unit. You need these drains, otherwise water would be entrapped in various cavities at the top of the lower unit and it could freeze over the winter, damaging the gearcase.
These holes are totally outside the oil-containing parts of the gearcase and you shouldn't worry about them unless they are plugged-up with debris.
Check out this old post which contains some good general information on changing out your gear oil:
http://forums.iboats.com/showthread.php?t=259698&highlight=gear+oil
HTH.........ed
smokeyblaze
88 bucks for a gasket set..I just need ti know what kind of gasket I need for the drain plug/screw my serial number is 5034003. I guess I can just use teflon tape?
gss036
Any boat shop will have them, usually in a 2 pack. I made the ,istake of buying from the Yamaha dealer, they soaked me a buck apiece for them.
Moody Blue
Don't use teflon tape. Its not the threads that provide the seal, it is a compression type seal between the head of the screw and the face of the screw hole.
I have started using o-rings in place of the usual flat fiber washer. I find I can re-use the o-rings while the fiber washers are a one shot deal.
As mentioned, you should be able to locate those drain plug gaskets at any marine supply shop. I used to pay about $1.00 ea also.
