I am in the middle of rebuilding this engine. When disassembling i could see flywheel magnetos had touched ignition stator coil, causing heat. I now replaced coil. Does anyone know a smart trick to place the coil with the right tolerance to magnets. I do not have an ignition ring, as used by pro's. I can easily get the coils away from magnets, but suppose charging will be weak if distance is to big.
