How to adjust idle on 1989 / 1990 Johnson 25 hp Outboard
n4cer26
The low speed idle while in neutral is to fast. No tach so not sure on the actual RPM but just by ear it is obviosly running to fast. How do I adjust the low speed idle? I have included a couple of photos of the motor. Thanks in advance.
Michawilden
There is a screw on the portside of the motor which controls the idle. You firstly have to make sure that your cable puls the throttle all the way back. If this does not happen you have to adjust your cables. Another problem can be that the roller of the carb hits the cam to soon. This also increases the idle rpm. On the cam, two notches are present. The roller should start to touch the cam between these notches. If it touches to soon, the idle will also increase.
If you have any questions. just ask.
