fiddlestix
- Joined
- Mar 29, 2007
- 13
i just overhauled the carbs and replaced the plugs. but the idle speed is at 1400rpm. do i need to adjust the idle speed? if so were and how? 87 150gt
Walker said:You need to do a link&sync as per manual specs. If you do that and it still idles too fast then back off the idle timing a bit.
yes it is with the muffs onandy6374 said:Is this in the water or on the muffs.
thanks i have a manuel by cylmers is it in that maunel or do i need another.tashasdaddy said:there should be a section on setting the link and sinc, in the manual, what if does is, synchronises the electrical timing and the the carbs so they work together, properly. it must be done in the step by step process in the manual.
fiddlestix said:yes it is with the muffs onandy6374 said:Is this in the water or on the muffs.
LubeDude said:fiddlestix said:yes it is with the muffs onandy6374 said:Is this in the water or on the muffs.
It will Idle faster with the muffs than in the water.
thanks for the help
