How to adjust throttle tension
Black Snow Slide
2006 VP 5.7 GI with VP DP outdrive. Throttle has no markings or numbers. Description of throttle: side mount on hull, trim for engine on T. Kill switch for lanyard on side plate of throttle. Throttle is OE when boat was purchased new.
I have been through the manual and all the throttle adjustments don't apply because tension screw are not where they say they are. I need to tighten mine as I need to hold throttle or it will self adjust faster and slower. Please post step by step of your throttle adjustment for tension Thanks in advance for help.
