Re: how to adjust timing,hi-speed solenoid,throttle linkage,mariner25
the engine is used for 5 months, 97 model but it was unused when I bought it. Story begin while I try to adjust air -fuel mixture by the reason of missing at idle, I did it and worked. Then I saw the throttle linkage nuts a bit loosed. I stratched them. After that I tried to adjust the idle screw. At the end the motor began to bog at sudden full throttle. <br />JB where are you??
