I need a little help with my '49 Gale Hiawatha that i just recently acquired. I would like to change the oil in the lower unit but cannot find the vent screw. If you're looking at the LU directly at the prop there is a drain screw on the left about centered with the prop shaft and a larger screw on the right that will not budge. I can not locate a vent screw higher up the unit. On the right side just above the screw that will not budge there are 4 open holes (see pics). I've looked at these open holes but do not see threads but is one of these holes the vent just missing its plug. Also i was considering not using oil but using Lubriplate 105. What are thoughts on this?
Thanks
Thanks
