Re: How to change the oil on a 305 Mercruiser
It took a couple of oil changes,......<br />But,......<br />I figured out the BEST way,.................
<br /><br />I rigged my pump to the end of the bilge-hole oil drain line,..........<br />Fast oil changes on the trailer,........ Or with My Extended Hose,.... At the Dock Too.........<br />And,..... All the oil comes out,.....<br />I Never did like the idea of sucking it thru the dipstick tube................
<br /><br />Another tid-bit,............<br />After you Crack the filter Loose,......<br />Use a Zip-Lock Baggie around the Oil Filter(or gas filter) to catch the Drippings,.......<br />Spin it Off,... Drop it In,.... Seal it Up....................
