Re: How to check bellows
Let's not jump off the deep end here, gentlemen. If you replace one, you do it all. You don't replace this bellows this year, another bellows next year, and the last bellows the next year. That ends-up costing you three times the labor and three times the downtime. You do it when it's necessary, and you do it all (including the water pump). It's expensive any way you do it, but nickle and diming it costs a whole lot more than if you do it all at once. And you don't do it until it needs to be done. I hardly think 3 or 4 years is that big of a deal. I'd be keeping an eye on it all, but I'd expect at least five years out of any of these (with the exception of the water pump...no more than three), and I'd ask no more than ten.<br /><br />Take the drive off and see what you've got inside. Check the gimbal bearing, check the engine alignment, grease the splines, and grease the u-joints if you can. Check all of the bellows, the hose, the shift cable, the trim limiter and sender wires. Change the gearlube. Then go from there. If it's on a trailer or a lift, you don't need to worry about it being as perfect as if it were moored. Use your judgement.
