How To - Check Coil Polarity
mthieme
Coil polarity is very important. If reversed, the spark plugs may demand 30-40% more voltage to fire. On most CD systems, there will be no spark.
Method 1 - With a DC voltmeter, connect the positive lead to a good ground. With the engine running, momentarily touch the negative lead to a spark plug terminal. The needle should swing upscale. If the needle swings downscale, the polarity is reversed.
Method 2 - Disconnect a spark plug wire and hold the metal wire connector end about 1/4" away from the spark plug terminal. Crank the engine with the ignition switch on. Insert a pencil tip in the arc stream. If the arc feathers towards the spark plug, the polarity is correct. If the arc feathers towards the wire, the polarity is reversed.
Chris1956
Re: How To - Check Coil Polarity
OK - I'll bite. How does the polarity get changed? Most if not all american-made engines are negative ground, and most if not all coils have one side grounded. The side to be grounded is usually quite obvious.
