Re: how to check compression 1996 130 yamaha ?
There is no spec for psi. The specs say all cylinders should be within 10% of each other. Typical is 100-125psi.
Ideally, warm the engine up first.
Remove all spark plugs.
1. Screw the tester into one cylinder. With the emergency stop lanyard out, turn the engine over at least 5 times. Note the psi.
2. Repeat #1 for each cylinder.
3. Lowest cylinder should be within 10% of highest cylinder.
