How to check compression?
apaseman
Is there any easy way to check an outboards compression or does one need a special device?
JoLin
Re: How to check compression?
Just a regular old compression tester that screws into the spark plug hole. If you know how to do a check on a car, you know how to do it on an outboard. If you don't, write back and we'll help you out.
When you get results. if you aren't sure they're good, post back with make, model and year in the appropriate engine forum and folks there will help you decipher the numbers.
H20Rat
just make sure to ground out the spark plugs or disconnect the ignition. lots of ways to destroy various parts with an open ignition circuit.
