i have a 1999 palm beach c/c with a 115 yam. it scaled out at 3400 lbs and looks like it sits low at the stern when in the water. i have run a snake thru the hull channels but found no clogs. after adding up gear, motor, trailer, approx. dry weight of boat i get an estimate of 2800 lbs. 600 lbs is a big difference. is it possible the foam is water logged? how can i check this? any other suggestions would be helpful. i posted this in the general questions forum and was refered to this forum. (and yes, i tried a search but had no luck).<br /> thanks
