Re: how to check for rot?
I have replaced fiberglass floors on small fishing boats that have been rotted out.. The floor was soft if I was to jump up and down on the floor. I have taken a drill and drilled into suspect areas. The drill holes will help lay out a pattern if you need to remove the fiberglass and replace the wood. An ice pick or screw driver will do but a drill is clean and a drill hole is easy to cover over or repair. It is difficult to find rot under fiberglass. If it is wood, and ice pick or screwdriver is the best way to find rot.
