I got a relatively cheap used portable inductive tach on ebay last fall. I use it to set idle speed timing during link and sync, as the dash tach is not precise enough for the 650-750rpm idle spec. It measures both a low RPMs and high RPMs so would suffice for checking your in dash tach gauge as well.
I just checked ebay and found the exact same tach on auction. This will give you an idea as to what I am talking about.
