I think i have a two part question
Johnson 70hp 1991 J70TLEIE
I have been checking my spark and everything i read is " bright blue thick spark" at 7/16 gap. Maybe im looking for a little more discription of good spark? Im seeing thick spark from one end of the tester, thinner spark coming from the other side so you can see a skinny spot almost in the middle where they meet. As i turn the key the rythm looks good but it misses one every once in awhile. Is this normal or am i looking at it too much and sniffing too many fumes?
Also when checking the timing i noticed the time light "misses" every once in a while. I even moved the time clamp to the other two wires to just watch the light. Cant tell if it coincides with the miss in the spark but i kinda see the same thing when checking the spark.
Idle time is supposed to be 3-5 atdc when i checked it we were running 4 btdc. Didnt catch the a or b till after i put the boat away.
Engine has a slight miss at idle that is making me pull my hair out.
thanks in advance!
thanks in advance!
