how to clean my points and set them
rtpogo11
hello i have a tas outboard model tob -12
i want to clean the points having issues with spark
the manual says to set the gap at 0.35 when i try to set gap i can't get the gap to open any more even when i unloosen adjusting screws you guys are the best
MikDee
Banned
Re: how to clean my points and set them
That sounds too wide, like a spark plug gap??? Point gap is usually about .016"-.020" Reheck your manual for point gap.
robert graham
Drag a strip of fine Emory cloth between the points while they are closed under tension....spray/clean with carb cleaner/acetone/alcohol/etc., then set then at the cam open position....should be something in the .015 inch range, give or take a couple....check your book for setting.
rtpogo11
it says no wider than 0.35 having trouble downloading pics this motor is making me cry
MikDee
Banned
I've never heard of points being set wider then .022"? I would think that the coil, or power source would not be able to jump a gap of .035", besides the fact that your setup is not letting you go that wide of a gap,,, Doesn't that tell you something? If it doesn't feel right, it probably isn't! Do you have spark plugs? Like I said, that sounds like a setting for the spark plug gap!
Starcraft5834
buy new points.. they are a few bucks....... .035 is spark plug gap
rtpogo11
I cannot get new points for this tanaka 1 hp outboard
duke33
......what is your spark plug gap supposed to be???
MikDee
Banned
You can use an emery board (like for fingernails) to dress them up, then some alcohol on a Q-tip to clean them.
