capslock118
- Joined
- Apr 27, 2009
- 249
Hi there,
I purchased my boat about years ago and as far as the oil goes, i've only refilled the reservoir.
So today, I wanted to change over the oil in the reservoir, reset it if you will, because its a very darkish color - not what i expect out of new clean oil.
What I found was some think chunky particles in the tank. The pipe that sucks the oil out when the engine is running does have a filter on it but i'm wondering:
what is the best method to clean the inside of the reservoir? Can I blast the inside with a hose with water and then just drain into a can for proper disposal?
also - i noticed when emptying the reservoir that there was another filter screen just floating in the can along with at least an o-ring. I'm not sure if there were any other parts inside the oil as it's so thick. Can you guess what that might be since there is already one screen attached to the line? a second screen that was suppose to be attached perhaps?
thanks
thanks
