Guys,
I had an LMF 200 Gauge and EP-60R Fuel Senor installed in my boat three summers ago (Chaparral Sunesta 252 with 5.0 EFI Mercruiser / Bravo III). The unit has worked flawlessly, however yesterday the fuel flow monitoring started acting up... the flow numbers displayed on the gauge seem to bounce around randomly from zero to normal numbers with most of the time the gauge showing ZERO as the flow rate.
I assume that debris and/or a bad sensor are the only possible causes, yes? If it's debris, is there any special way to remove, inspect and confirm this cause? If it is debris will I see it? Is there a way to clean this sensor?
Thanks!
Bradesp
Thanks!
Bradesp
