How to clean the block to reinstall heads?
cliffblue
I'm trying to clean the block on my 4.3 to reinstall the heads and intake. I have scraped the surface with a gasket scraper then a razor blade scraper. The block is smooth but obviously not down to bare metal. Will a synthetic scrub like scotchbrite leave abrasive particles in the cylinders like emery cloth might? I want to get it as clean as possible but not leave abrasives in the rings. Thanks, Cliff
Jiminthekeys
Re: How to clean the block to reinstall heads?
Acetone and a razor blade has always done the job for me.
stonyloam
Once you get most of the stuff off you could try lightly draw filing the block and heads. Watch this http://m.youtube.com/watch?v=rQYSroXM0Go stuff towels in the cylinder holes to keep filings out.
I believe scotch brite has aluminum oxide embedded in the fibers, so any pieces that drop into the holes could be a problem.
thumpar
They make gasket remover. It works great but you have to let it soak in.
GA_Boater
Gasket remover, a razor blade and vacuum. No matter how many rags I stuff in the bore, crud always gets past, so I use a shop vac.
cliffblue
I will look for gasket remover and I have the vac. Thanks
Walt T
I use a black and decker spinny thingy from home depot and get some 3m fiber abrasive pads at NAPA along with an adaptor for the pads. Gets it all perfect in a few minutes at 20,000 rpm.
