Currently, my air pump for the inflatable towables has aligator clips so that it can be connected directly to the battery. This is a *huge* hassle since access to the battery is pretty limited. Any suggestions on where else to hook it up to?<br /><br />I tried plugging into the cigarette adapater after purchasing a cigarette adapater male part, but blew the fuse since it requires 14Anps initially and 8Amps under load.<br /><br />Should I just pull wires from the pos/neg (fused, of course) to someplace more accessible and hook up there? If so, what gauge wire and what should I use for the final connection between battery and airpump wires? Any other suggestions?
