Most posts in this forum seem to compare specific engines, trucks, hitches, etc. Taking the brand out of it, I'd like to hear about your experience towing. Is the listed towing capacity of a vehicle something to trust (assuming you know what you're doing, correct hitch, brakes, etc)?
For example, if your vehicle is rated at 10,000 lbs towing capacity, can you really tow a 10,000 lb boat? Considering the fact you will be going up a steep incline on the boat ramp, perhaps not. If this is true, then what percentage under the rated towing capacity should you expect to achieve? Perhaps that 10,000 lb capable vehicle can only tow 9,000 lbs of boat, trailer, gear, etc? What margin of safety should you look for?
What do you think? How does 4x4 play a role in this decision?
Thanks!
Travis
Thanks!
Travis
