How to determine .125 BTDC on a 73 Eska 9.5 outboard ?
Just Bill
I am in the process of replacing a CDI 110-958 stator in my 1973, 9.5 ESKA and the ESKA manual states to set the top cylinder to .125 BTDC. I know this is 1/8 of an inch but cannot find any " how to " information elsewhere. Finding TDC is not an issue. I have both of the tools from Tecumseh to set the timing, # 670243 and # 670244. Any help would be appreciated.
Thank you.
Just Bill
Just Bill
Thank you.
Just Bill
Just Bill
Hello brim buster,
Thank you for your response to my post. The information you sent is for a single cylinder ESKA up to 7.5 HP with a solid state stator and ignition points. I do have this section of the ESKA manual. In addition, I also have the part of the manual pertaining to my issue, model 1925A, a twin cylinder, 9.5 HP with a solid state stator and no ignition points used. The manual calls for different special tools for each situation and I do have the necessary tools for my application, parts # 670243, # 670244 ( see pages 20 and 21 of the ESKA Mechanics Service Manual ) . It appears the timing etc. on the single cylinder is even more involved then my issue. I have come to the conclusion I must revisit the instructions and go slowly through each step and hope I have done it correctly before starting the outboard up.
I would appreciate any other thoughts you may have.
Thank you.
Just Bill
