reelfishin
- Joined
- Mar 19, 2007
- 3,050
Over the past year, I've scrapped probably around 40 or so boats, this has left me with a pretty good supply or premixed gasoline. The problem is, the when pumping out a tank on a boat destined for the big boat yard in the sky, I have no idea on how old the fuel is, or how much oil has been mixed in it. I've run a good bit of it though the yard equipment and even some in my old truck with no problems in the past but I've never trusted the oil content or condition to use it in any of my boats. Unless I knew the owner and was able to test run a motor with the fuel on board to some extent, I don't think I'd chance it in one of my own motors.
The point is now that I've got probably 7 or 800 gallons accumulated. Most in barrels stored in an outbuilding and some still in portable 5 gallon tanks as it was removed from the boats.
What really got my attention was one which I cut up last week, it had twin 100 gallon tanks, both full, two 25 gallon above deck tanks, also full, and 4 6 gallon portable tanks onboard, all full. The motor was running on the portable tanks.
I pumped each tank separate and checked for water, and all was clean, the motor was a premix motor, early 70s V4 and all tanks were still plumbed to the motor with various fuel lines and primer bulbs. The fuel has a gray blue look, so its got oil in it, but like so many others, I have no idea how much or how old, only that it appears free from water and didn't separate at all in a glass jar overnight. It smells fine, don't smell like old gas, and a sample runs fine in my lawn tractor with only some minor smoke. I've not yet run across any with really bad or stale smelling gas, at least not in any boats using premix. I am also curious if they add anything to two stroke oil to help stabilize the gasoline. I had one boat that I know sat for over 6 years, and I burned that gas in my old truck with no problems.
(I've since upgraded my shop truck to one more economical but I don't think dumping all sorts of old fuel into a modern fuel injected engine would be good idea, the old, carbureted, no catalytic converter, rust bucket didn't mind though).
Is there a way to determine the oil content or a way to maybe filter it out altogether as not to waist this much free gas?
