phillnjack2
Ensign
- Joined
- Apr 30, 2011
- 918
1995 Evinrude 60hp
Model no BE60TLEOC
Hi guys
I looked at the "joe reeves " way of checking the max advance/wide open throttle timing procedure.
first thing he mentions is to disengage the quick start if you have this on your engine.
well yes mine has this feature.
but how do I disengage the quick start so I can check max advance timing.
im sure its been told to me before, and explained in great detail, but I have forgot it and cannot find it in my files
that I normally keep.#
(cant find most stuff i want to look at due to new computer ).
I want to check max advance timing without having to lean over the back of the boat doing 40mph.
on my engine it states 17 degrees BTC so I presume with Joe's method I just set it
to 13 degree spinning on the starter motor then engine when running will gain its other 4 degree's ?
Any help on this would be real good.
Model no BE60TLEOC
Hi guys
