How to extract KE-4 water pump impeller "cover'
I was able to get the plate that it's behind off by turning it right hand thread... But do I pull this cover out with a puller? Or do I also
twist it out right hand thread? Thanks for any help, Kent
Chinewalker
The plate behind the threaded cover should just fall out if you invert the unit. Or, maybe try a magnet.
hmm.. ok, thanks for letting me know. It appears to be stuck in there somehow, tried pulling it with the 2 diametrically opposed screw holes it has in it. But now that I know it isn't attached in some way I guess I can try some more methods.
