AZcamperguy
- Joined
- Feb 28, 2009
- 130
I have what I believe to be a '76 9.9 outboard. One of the clamps is bent or something because I broke the handle off trying to turn it and then I used a pipe wrench to turn it. Now that it is coming out the back side (tightening) it appears to be stripping.
Should I cut the end off and then back it out? I( have a feeling that I will end up needing to re thread the hole when it comes out. Will I be able to find a replacement clamp for it that is slightly bigger? Is there a better way to go about fixing this? Should I just try to find a replacement for the whole mounting bracket?
