how to fix a small screw hole?
wcsparky05
i have the tip of a screw poking out of my boat aboat 1/8". how do i fix it and is it something i can do myself? thx in advance.
Robj
Re: how to fix a small screw hole?
Just do a search on this site, you will get many hits. Basically remove the screw, fill the hole with marine tex ( I believe that is what it is called ). You could also fibreglass it, but that is much more work. Easy repair, nothing to worry about.
Have a great day,
Rob.
lexkyboater
How do you repair the color after a repair with marine tex?
gcboat
If it's on the bottom I wouldn't worry about. If on the side and you don't want to see it then you'll need to use gel coat to match. Two different products - two different applications. :D
wcsparky05
thx everyone. now i must go do laundry!
