how to get a 72 85hp selectro out of gear w/out controls
shawpdx1
Trying to do a compression test on this motor cant get it out if gear to do this I move the arm back and forth but I think thats just throttle. I just get a lug since its in gear thanks In advance
tashasdaddy
Re: how to get a 72 85hp selectro out of gear w/out controls
you need control
Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
shawpdx1
If I read this right disconect the 2 kinfe leads from the powerhead to lower unit and apply juice from the sileniod to green wire and then im in N then I can do the comp-test?
shawpdx1
correct? power to the green wire? for N
shawpdx1
worked like a dream, Its has 130 per hole think guess thats worth getting running obviously the lower unit works no water in there \ go or no go?
tx1961whaler
Compression is good. Just check reverse (just add 12V to the blue wire) and go.
jay_merrill
Double check the shift switch in the control box too. Test both the green wire and the blue wire at the same knife connectors that you separated previously. This time, use a mutimeter and test from the "upstream" side of the blades. Have someone shift from neutral into reverse, as needed. Make sure the key switch is on. You should get 12VDC on each of them.
tx1961whaler
Take good care of the control box. It is worth more than the rest of the motor (seriously).
