lakeorbay
- Joined
- Apr 15, 2009
- 180
I've had to walk away from this project more than a few times. It's not easy digging foam out of such a small area. Well, I dug it all out and I still can't get it to break free. I guess the pressure of the foam and any little thing the foam has formed around is working against me. It's really too bad, because of all things on the boat, it's the most solid install on the entire boat and here I am ripping it out. I could use some suggestions before I go to plan B.
Correct me if I'm wrong. I think I recall someone referring
to the plate I circled in the pic as a 'bulkhead'. Plan B is to remove it and take the tub out from the side. I don't want to because it seems to be a key structural piece and it's riveted all the way through the hull. I have a rivet gun on the way, but I would still like to stay away from that.
Here's the plate with rivets all the way across the bottom.
I dug down past the bottom and the corners.
I didn't want to cut the pick up hose, but oh well, casualty.
