Re: how to get boat from 0-25mph faster?
I am not sure what the pitch of the prop is..... How can i find out? I only use the boat for tubing, wakeboarding and kneeboarding, so i am just looking to get on plane faster or at a lower speed.
Thanks Andrew
before you go buying anything get what you got right.
prop: if it's not marked anywhere on the outside, then pull it off and look at the hub. many are marked or stamped... the one on the floor next to my desk says 14.5 x 27 - meaning 14.5" diameter and 27" pitch. if you only have a serial number often times you can figure that one out.
I would be shocked if your running a high gear ratio like from a 4 cyl and turning max 2500 rpms on a 302. unless your tach is way off, you're running a lower gear (ie 1.5 or the like) or have engine "issues" unless it's a barge of a boat and way overpropped.
How does it sound when you run it at max rpm? couild it just be the tach? If you have a friend with or can beg borrow, steal a timing light with electronic advance and an rpm reading on it, do it and check your tach. might as well check the timing as well while you're at it. give it a complete tune up while you're at it (unless been done recently), make sure it's running on all cylinders and so on. Not saying this will fix the problem, but if it needs done do it and it'll remove some questions you need to answer anyhow.
imho...
