how to get more speed out of a 15hp 4 stroke yamaha
i have a 2002 4 stroke yamaha .how can i get more speed out of it .can i go from a 9 1/4 x 10 1/2 aluminum prop to a 9 1/4 x 11 pitch prop.will it have enough rpms.this is my first 4 stroke and it does not seam to push boat as fast as my 1989 evinrude 2 stroke.any help would be great on more hp or spped.it is on a 2007 14 foot aluminum flat bottom boat i use for river fishing
thanks
steelespike
Re: how to get more speed out of a 15hp 4 stroke yamaha
OK; its very difficult to make any changes without some specs.You will need a tinytach for RPM,and a gps for speed.Tinytach is reasonable, easy to install and will fit any similar 4 stroke without regard to stator poles.In the mean time describe its performance,typical load,Hole shot,load pushing,approximate top speed.
The little 4 strokes require very careful setup need to run at max rpm.
Careful prop selection based on the present prop,max speed and rpm will help. You can raise the motor vertically 1/4" at a time by placing sticks on the top of the transom.Raise it to a point just before venting becomes a problem.just be sure it pumps water and has a good grip.careful trim selection.Could get you a little more speed and slightly quicker hole shot.Eliminate weight.plastic oars instead of wood,3 gal plastic tank instead of a steel 6,No unecessary items aboard.
light styrofoam cooler with cans no bottles.Less ice but shade the cooler.
Carefull weight placement.Once you have your specs prop selection should be easier.
what rpms should a stock 15hp yamaha 4 stroke from factory run
Silvertip
5500 RPM at wide open throttle with an average load.
