I am ready to install the lower unit of my 1975 85 hp Johnson, I have an extra long bolt I have inserted in the rear bolt hole of the foot to hold the foot while getting everything else aligned. My main concern is I can not see or feel the water tubes to get them to go into the holes in the top of the water pump. I read somewhere that the tubes slide down, is this true, if not how are the tubes lined up?
If the tubes don't pull down, is there something i can slide up around the tubes that will slide up and align the tubes into the holes?
One more question, the shift rod housing has oil in it, is that the same oil as in the gear case? If so, what keeps water out of the oil there. Water can go into the oil through the shift rod.
